Autowatch at Component or Project Level
Deleted user November 9, 2012
Hi all. Is there any way (either built-in or plugin) that would enable someone to autowatch issues based on either Project or Component? And when I say "autowatch", I don't mean for those that have either created, commented, or edited an issue (like the new feature in 5.x). I mean to automatically get added to the watchers list when a bug is created, commented, and/or edited even if that person didn't do the actual creating or editing. As a manager, it's very helpful to watch a specific component and be notified immediately of any new issues or updates to existing ones without having to manually add myself as a watcher to every bug.
I've tried to get around this by creating a subscription that looks for any new or changed bugs in the last 15 minutes. The problem with this is that the email only tells me what bug is new or changed -- not the diff or contents of the change.
Does this make sense?
Jobin Kuruvilla [Adaptavist]
November 9, 2012
Totally missed this. I think this is exactly what I'm looking for. I think ideally it could be done by each user but having the admin do it is almost as good.
Eric Mitchell March 20, 2013
What are the options if I'm using the ondemand version not supported by this plugin?
Mike Lazzaro
January 27, 2017
I know this is an old discussion, but in case anyone ends up here looking for a Cloud-compatible version of this, there's a free add-on called "JIRA Autowatch" available in the marketplace. Some of the reviews indicate it's not working for some people, but I'm currently using it and it seems to be working fine, aside from the fact that the JQL rules apply globally, not at a project level (contrary to what's stated in the docs).
https://marketplace.atlassian.com/plugins/com.atlassian.addon.connect.jiraautowatch/cloud/overview
