BULK EDIT ISSUE Using JIRA REST API
Karan S May 2, 2025
I tried using Jira's bulk edit issue but it works fine when i try to add labels to a work item but throws error when i try to edit description or summary.
This is the payload i used for editing labels,
"editedFieldsInput": {
"labelsFields": [
"bulkEditMultiSelectFieldOption": "ADD",
"fieldId": "labels",
"labels": [
"name": "Test"
"selectedActions": [
"description"
"selectedIssueIdsOrKeys": [
"BBD-574"
It worked perfectly fine. This is the payload iam trying to use for description,
"richTextFields": [
"fieldId": "description",
"richText": {
"version": 1,
"type": "doc",
"content": [
"type": "heading",
"attrs": {
"level": 3
"content": [
"type": "text",
"text": "Story:"
"description"
"BBD-574"
It is throwing error like check the payload something. WHat am i missing here?
3 votes
Dick
Hi @Karan S Welcome to the Atlassian Community,
There's a comma too much within the square brackets belonging to the "content": [   ]   bit.
Your element within (nice boundaries with curly braces, is followed with a comma that would suggest another element. But there is no second element, so the parsing goes wrong.
Dick
Karan S May 2, 2025
data = {
"richTextFields": [
"richText": {
"version": 1,
"type": "doc",
"content": [
"type": "heading",
"attrs": {
"level": 3
"content": [
"type": "text",
"text": "Story:"
"description"
"BBD-574"
I tried that also its still giving
2025-05-02,18:58:48 __main__:1751 - ERROR:{"errorMessages":["Invalid request payload. Refer to the REST API documentation and try again."]}
Not sure what am i missing,
Jim Knepley - ReleaseTEAM
@Karan S, I agree with @Dick, trailing commas are fine in JavaScript, but aren't valid for JSON documents. In your updated reply, there's a trailing comma at the very bottom.
https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Trailing_commas#trailing_commas_in_json
Karan S May 4, 2025
I tried its still same issue. I think summary and description fields can be edited during bulk epic I think
Karan S May 4, 2025
Like Dick likes this
FREE
