Backup Jira System and Restore another Jira Server with automation ( powershell or sh)
brk gsw July 25, 2023
I have two Jira Servers. Jira Software (Data Center)
I want to export a project to another Jira server. For this aim, under the system, I am restoring the system. The backup file is saved on ": /var/atlassian/application-data/jira/export"
Secondly, I am saving this file to target Jira server's " /var/atlassian/application-data/jira/import" folder.
After saving to target Jira server's import folder, I am using "Project Import" . This support to choose desired project on backup system file.
For example on source Jira Server there are tree projects. After restoring system, I am saving this backup file to target Jira Server's import folder. Later, when I use "import Project" section, Jira ask me "you have 3 project on your backup. You can choose whatever you want".
After choosing desired project. I gain success on export import operation.
MY QUESTION is How can I automate with script? It will be powershell or sh.
I need a script that export system or specific project on a target Jira. Or It will be save the backup file to a file on determined target.( For example destop etc)
I need a second script that send the backup file to import the target Jira server.
To sum up I want to export and import project within the different Jira servers with aoutomation.
I need Rest api or powershell script or sh file.
Thanks.
2 accepted
brk gsw August 2, 2023
Hello Artur, This post for backup jira Cloud. I need a Jira server backup script.
Do you have any suggestions?
Acccording to Pierangelo Repetti answers the  "backup-jira-api-token.sh" does not available.
Artur Moura
July 31, 2023
Hi @brk gsw
I found this post which I believe should help you with your automation.
Please let us know if it helps.
SERVER
