×Is there an easy barcoding solution you can use with Insights? Need a simple way to scan barcodes and have it entered into Insight.
To easily integrate barcode scanning into Insights, consider using Dynamsoft barcode reader, a Bluetooth or USB scanner, or a browser extension. Ensure compatibility with your barcode format, define how scanned data will be mapped to Insights fields, and utilize automation tools for efficiency. Prioritize security measures for sensitive data.
Hi @Alvin
You may want to try the following plugin: https://marketplace.atlassian.com/apps/1219263/scanstar-for-insight-and-jira?hosting=cloud&tab=overview
Uses a barcode to update insight object schemas.
