I am working on an e-commerce platform Hellstar and looking for the best way to integrate our custom order management workflows with Atlassian Jira for seamless tracking and automation.
Our key requirements include:
Has anyone implemented a similar integration? Would Jira Service Management or Jira Software be more suitable for this use case? Any recommended plugins or APIs that could help streamline this process?
Looking forward to insights from the community. Thanks!
While this can be done in Jira any of these high level custom options I generally recommend staying away from. What it sounds like you need is a CRM system, Jira is not a CRM system.
You can make it into one, we did at my previous company, however when they needed to tie it into the correct system later on it took them over two years to move away from that process.
So while Jira can do a lot, it's often better to get the right tools for the job from the start rather than make one tool do everything. If you make one tool do everything you create one single point of failure which isn't generally recommended.
If it's something you want to pursue I would recommend partnering with a Solutions Partner: https://partnerdirectory.atlassian.com/
However especially for what you are trying to do and this is exactly what my old company did, I really would recommend against it.
Best,
Clark
