Best practice to visualize Jira issues dependency
Idiyana May 12, 2024
What is the best way to visualize issues in Jira with below cases:
  • Teams involve have different definition of start/end date
  • Each teams has different way of creating issues for their work items. some create story, some create task
  • Each issues has unique workflow steps and statuses. some have a simple workflow steps, some have a complex workflow steps
Appreciate if anyone can suggest the best way/tools for us.
Metricus
Process Mining is a technology that allows for visualisation of processes and workflows.   The Metricus Process Optimizer, a solution my company has developed.  It utilizes Process Mining to provide an x-ray view of the different types of workflows that occur.   Multiple activities such as status and assignments can be tracked across multiple issue types and projects.   Check it out in the MarketPlace at https://marketplace.atlassian.com/apps/1230330
