Im working with a medium size organization that has all of their internal teams using company-managed service projects (HR, Finance, Payroll, IT, etc each with their own project).
The services they provide are available to staff through a portal, all good.
However, when an issue requires activities from several different teams they dont have a good way of collaborating. Several of the projects contain sensitive information, so providing Service Desk Customer access to other teams is not an option.
An example use case is: A user who is leaving the company raises a query to the Payroll project asking what their final paycheck amount will be. To answer this, Payroll need the HR team to confirm end date, outstanding holiday etc. Both the Payroll Project and HR Project contain sensitive data, so neither team can be able to the issues in their queue. Both teams would like an issue for their work, so it appears in reporting/stats.
What the best solution here?
Im currently thinking of providing the Create Issues and Link Issues permissions to Jira Software Users, which I believe should enable teams to create linked tasks in different projects to collaborate, and should be scalable as more teams begin to discover the need to collaborate between projects.
Is there any downside to this approach?
Hey @Benjamin Stapleton,
thank you for the detailed description of your use case - that helps in providing a good answer.
You asked:
If I understood it correct, people from one team shouldn't be able to view issues in another team's project due to data security reasons, right? Therefore giving them create and link permissions might work, but they wouldn't be able to see it afterwards anymore.
I see multiple possible solution approaches for this:
There are probably also some other ways - that's all which come to my mind right now.
Matthias
PS: I'm part of the team behind Backbone Issue Sync which can offer you the third solution approach.
Thanks Matthias. In this case the user raising the linked ticket will be the reporter, so they will be able to see their own ticket in another project, but not any other tickets.
I have this running in test and seems to work well. Ill report back any other findings.
Hi @Benjamin Stapleton ,
Thanks for posting your question here on the Community.
I am Dhiren from the Exalate Team.
Cross Project collaboration needs have increased drastically in the last few years due to increase in size/demand of projects, people, use-cases etc and I would recommend you to use a fully decentralized and customizable bi-directional integration solution Exalate in this case.
Although Security Schemes and Automations can work sometimes but it's still not the best solution for an effective collaboration and that is where a dedicated integration solution can help!
With Exalate you can synchronize issues between multiple projects with all fields (system + cusotm) bi-directionally, and it's even possible to create issue links/sub-tasks easily.
It also provides a Groovy based scripting engine for unmatched customization and flexibility.
Thanks, Dhiren
@Benjamin Stapleton hey there. there are plenty of options available. each member of the atlassian community will probably share the one that fits their own criteria in terms of cost, easiness, effectiveness and use case (in particular). in the end, it's all up to you :). i'll just drop an alternative to the tools already listed here and you can check it at the atlassian marketplace - ZigiOps. it's fully no code, can easily be deployed and customized in various ways.
Regards, Diana
