Best way to automatically fill a system field based on a custom field
Eduardo Perez Soto
April 19, 2022
I have a custom field called Story points and based on this field, once this field gets a value, I would like to automatically populate the time estimate with a conversion. My question is, what would be the best way to implement this, using listener or behaviors?
Sam Bartolome
April 19, 2022
Hi @Eduardo Perez Soto ,
I would say the easiest and simplest will be to use Automation or or a post-function, but based on which apps you have.
The post-function has the limitation that it should happen only the stated transition otherwise it will not be caught anywhere else. Automation can bypass that as well as a listener but the latter requires more configuration
