I like jira and the project issues. But as projectmanager, I have requirements for a professionell and modern management.
f.e. I have this "normal" structure: Epics->requirements->working packages
It's no problem to structure alle issues in a list and sort for types or dates and so on.
But first, I need a real tree structure: per requirements, I want to see the linked issues. (I saw in my kanbanbaord-Backlog a tree structure for working packages under the requirements)
And I want to see all needed times (work, elapsed and so on ) in a view.
Is that possible without additional plugins? The plugin "Structure" is an ideal tool, I know.
bye, Thomas
Hello Thomas,
also a warm welcome to the community. You are right, Jira doesn´t offer nice option to structure the issues, especially when it comes to requirements management.
Sorry, when I jump in here as a vendor. We have developed a add-on "R4J - Requirements Management for Jira" which allows you flexible structure your issues in a folder hierarchy. You can use you standard Jira issue types (or extend with customer and functional requirement types) to organize your project. We offer different views (tree view, reading view like a document, tabular view) to manage it, an coverage and traceability view to analyse you traces/links and export/import features.
If you are interested in a demo, please leave us a message in the service desk.
Best Regards
Bernhard, ease solutions
Hi @Thomas Bastian !
It is very difficult (if not impossible) to have more sturdy projects in Jira without apps. My recommendation:
Yes, I know these plugins. But sorry, I need a solution without plugins.
but, thanks
Hi Thomas, welcome to the Community. Certainly Structure is well suited for this I expect. However, here is what I have done to manager traditional project management. I used Confluence to create traditional context about a feature/release, etc. I create a page and layout the goals and create a table for all requirements. The headers might look something like this:
Req#
summary
details
required/optional
phase
test case#
I fill in 2-5 as a Product Manager then I have the development manager create Jira issue in Column 1 and my QA manager (later) fill in column 6. Further, the QA manager would link the test case Jiras to the dev Jiras.
Hi Jack, thanks for your welcome.
that is traditional management, yes. But my problem is in Jira and not confluence. Confluence is much more flexibel but have no issue database for statistics.
I need a solution in Jira as projectmanager.
So why can you not use Jira for your stats? What stats are you wanting to query? I use Confluence only as a means of getting started and setting context (words) for a given initiative. I can use Jira to determine the number of requirements done vs. not-Done fore example and similarly I can query stats on my testing. I can use Epics, labels and custom fields to break the larger initiative into phases, etc.
ultimately you will not achieve full Structure-like capabilities in standalone Jira but depended on your requirements you can often get close enough.
