BigPicture vs Advanced roadmaps/Plans in Jira premium plan
Sebastian Krzewiński
Hi
I'm using Jira with standard plan and installed BigPicture app. I'm considering to move Jira plan from standard to premium. I see that in premium I will have Advanced roadmaps/plans available.
Questions:
  • Will I be able to transfer BigPicture plans to Advanced roadmaps/plans?
  • Will Advanced roadmaps/plans cover all BigPicture features with similar or very close quality?
My goal is to have all Premium plans features but also don't break users way of work with switching BP to other solution.
Seba
Mirek
Hi @Sebastian Krzewiński
Overall this which PPM to choose is a very hot topic.. There are many places on the web where all those kind of tools are compared and it seems that in this specific scenario it covers everything but as you probably know on paper everything could be done but as it is in real life the best way is to simply check in practice.
Is the move to Premium related to how AR would replace BP? Since I think when you already are using BP and when you gain ability to try AR I think you can simply ask your users to try things out which would make this fully transparent and honest.
Making a decision to switch tools for them by simply saying you used this but now you would use this is not actually the best solution.. so involving users and getting their feedback is recommended way to go.
