any issues created on Bitbucket doesn't appear on JIRA. It's the same, when I create issue on JIRA, it doesn't appear on BitBucket
I have:
What should I have wrong? Thanks
The linking between JIRA and Bitbucket does not copy Bitbucket issues over to JIRA, or vice versa. The intention is that you use either JIRA, or the Bitbucket issue tracker.
For those using JIRA, the DVCS Connector makes it so that whenever you mention a JIRA issue in a commit message, comments, etc, Bitbucket will make it a link to your JIRA instance. However, you'll still want to turn off the Bitbucket issue tracker. It's a separate thing from JIRA.
Well if that's the case, then there should be at least a fourth option in bitbucket to change the link to the JIRA page
Crazy that it's so hard to figure this out. Poked around the JIRA and Bitbucket docs for hours thinking there had to be a way to auto-populate Bitbucket issues in Jira! Then found this post. Thanks Erik.
We have opened the below request to have the documentation update:
Settings screenshots
