Broke my jira installation, can't get it running again..
Blommetje
Had a JIRA install up and running, but messed it up. Uninstall did not work, so removed the folder. did a new, clean install, but it won't run anymore.
Any ideas on this?
Thomas Schlegel
Hi Maarten,
look here: https://jira.atlassian.com/browse/JRA-24468
Cheers
Thomas
Blommetje
There was 1 service under the Services menu in Windows. I was not running. I started it, and now it works again.
Hopefully it will work even after a reboot, when Services are started...
Mb
lance_lyons
January 4, 2012
You want to do SC DELETE <servicename> before you install again
the service name is the name shown when looking at the service properties.
Blommetje
Good thing i'm an idiot, because it did not take long at all!
this is the log file:
[2012-01-05 15:50:24] [info] Commons Daemon procrun (1.0.5.0 32-bit) started
[2012-01-05 15:50:24] [info] Service JIRA050112154923 name Atlassian JIRA
[2012-01-05 15:50:25] [error] The name is already in use as either a service name or a service display name.
[2012-01-05 15:50:25] [error] Failed installing 'JIRA050112154923' service
[2012-01-05 15:50:25] [error] Commons Daemon procrun failed with exit value: 7 (Failed to )
Blommetje
Well, in my attempts of trying and trying i just removed the last version, so no log file.
I can only do the install 1 more time, recreate the bug and check them then. Will do that, but will take a while...
Jobin Kuruvilla [Adaptavist]
January 4, 2012
Seems you have a service with the same name. Looks like you removed the folder but forgot to delete the windows service!
Septa Cahyadiputra
January 4, 2012
Hi Maarten,
Seems that you haven't remove the previously created Windows service. You might want to delete the previously created service or create a new one with a different name.
Hope it helps
Nic Brough -Adaptavist-
January 4, 2012
What does the log file say?
Septa Cahyadiputra
January 4, 2012
Hi Maarten,
On this kind of case, the recommend way is to contact Atlassian support trough this site https://support.atlassian.com.
You would get the appropriate method support from there from Atlassian support engineer.
If you would like to troubleshoot yourself, you might want to check this following file
  • catalina.out (<JIRA_Install_Dir>/logs/catalina.out)
  • atlassian-jira.log (<JIRA_HOME_Dir>/logs/atlassian-jira.log)
The above files might give you some clue on what happen on your instance. You might also want to check JIRA knowledge base to check if there are any known issue related to your case.
Hope it helps.
Septa Cahyadiputra
