×Hi,
We would like to limit project access by epic.
Our need is work with providers in a project, but each provider only would see his epics and related user stories.
Do you know some setting to achieve this?
Thanks.
Depending on how many providers you have @[deleted] answer could get messy and complicated. Another option would be to have separate projects for each provider.
Hi @[deleted],
Have you tried using the Issue security levels feature?
Issue security levels are created within issue security schemes and let you control which user or group of users can view an issue. When an issue security scheme is associated with a project, its security levels can be applied to issues in that project. Sub-tasks will also inherit the security level of their parent issue.
https://confluence.atlassian.com/adminjiracloud/configuring-issue-level-security-776636711.html
Hi @Ollie Guan,
Thanks for your answer.
Yes, I do. I tried to configure some Issue Security Levels, one per supplier. But when I created a user story related with an epic that had security level configured, the user story didn't inherit the security level of the epic.
I think that could cause some trouble.
