×When I go to the browse page of a project. JIRA does not show any content.
I just upgraded from JIRA 4.3 to JIRA 5.0.
Any ideas what could be wrong?
Also see the screenshot attacted.
If you have a plugin that provides an incompatible project tab panel this can happen... eg I know certain versions of the subversion plugin can cause this. I'd try disabling some plugins and see how you get on.
Also check your logs, that will tell you.
I had the same problem after upgrading a series of plugins.
I solved it by disabling/enabling greenhoper plugin.
Dont even bother yourself about other stuff..Its a plugin that causes that. I installed on eof the plugin recently and oppsss, i had issues, then i disabled that plugin and the problem was sorted.
