Browsing a project's issues does not display unresolved by priority/assignee
Patricia Wiebe
I am in the process of upgrading to Jira 4.4.3. I have set up my test environment and imported my data. When I browse the projects, for one project I am not seeing the list of "Unresolved: By Priority" and "Unresolved: By Assignee". I have 4 projects, and 3 display the information, but one does not. I am trying to understand why one would not display the information. There are open and in progress issues (92 in total). The Status Summary lists the issues and status fine, but the unresolved section lists there are no issues.
I'm at a loss. I can get that information in other ways, so I don't think it's a permission thing. Could there be a setting somewhere that this newer version of Jira honors that the old one didn't? (I am coming from 3.13.1)
Is there somewhere that shows how that Issues tab on the Browsing Project page is defined. If I could find that, perhaps that might be a clue.
Thanks for any thoughts!!
Dieter
November 15, 2011
Maybe the issues you expect to see have a non null 'Resolution' field value for some unknown reason. Could you check this?
Patricia Wiebe
I went ahead with my upgrade, and have the same behavior for this project in production. I currently have 142 issues that are not closed or resolved in the project. When I queried the database in the jiraissue table, I got back 142 rows, and every row had a null resolution and null resolution date. Each has a priority and assignee, yet when I look at the issues tab under the project, I see 142 in the staus summary, but no issues listed under the unresolved: by priority and no issues listed under the unresolved: by assignee. I have 4 other projects, and they all display normally - it's the strangest thing!
Patricia Wiebe
No, I had the log open while I tried a few things, and there were no errors. I did not find any exceptions in the log at all. I did see a few queries in the atlassian-jira-slow-queries.log file, but they were not related to this project and did not log when I accessed this project's issue page.
Jobin Kuruvilla [Adaptavist]
November 9, 2011
Any error in the logs when you browse that project?
Patricia Wiebe
Thanks - I had reindexed, and just for fun, I did it again, but it made no difference.
November 9, 2011
Try reindexing and see if that helps!
