Bug Search for Issues after upgrade to Jira v.6.2.4
Erica Paulini June 2, 2014
Hi everybody,
I have some problems after upgrade to Jira v.6.2.4.
The filter Search for Issues doesn't work, I display an error message:" 500, Sorry, we had some techincal problems during your last operation."
The same message appears when I don't write the correct PKEY in the Global Search
Can you help me?
Thank you so much everybody,
Erica
Yes I have tried but I don't solve the bugs
Norman Abramovitz
June 2, 2014
Have you tried reindexing yet?
I have notice that the standard filter " My Open Issues" doesn't work. I display this error message:
Referer URL: https://prj.opensymbol.it/secure/Dashboard.jspa
com.atlassian.cache.CacheException: java.lang.NullPointerException
	at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:67)
	at com.atlassian.jira.issue.fields.config.persistence.CachedFieldConfigSchemePersister.getFieldConfigScheme(CachedFieldConfigSchemePersister.java:89)
	at com.atlassian.jira.issue.fields.config.manager.FieldConfigSchemeManagerImpl.getValue(FieldConfigSchemeManagerImpl.java:72)
	at com.atlassian.jira.issue.fields.config.manager.FieldConfigSchemeManagerImpl.getValue(FieldConfigSchemeManagerImpl.java:63)
	at com.atlassian.jira.issue.fields.config.manager.FieldConfigSchemeManagerImpl.getRelevantConfigScheme(FieldConfigSchemeManagerImpl.java:322)
	at com.atlassian.jira.issue.fields.config.manager.FieldConfigSchemeManagerImpl.getRelevantConfig(FieldConfigSchemeManagerImpl.java:292)
	at com.atlassian.jira.issue.fields.CustomFieldImpl.getRelevantConfig(CustomFieldImpl.java:649)
	at com.atlassian.jira.issue.fields.CustomFieldImpl.isInScope(CustomFieldImpl.java:312)
	at com.atlassian.jira.issue.fields.CustomFieldImpl.isInScope(CustomFieldImpl.java:297)
	at com.atlassian.jira.issue.managers.DefaultCustomFieldManager.getCustomFieldObjects(DefaultCustomFieldManager.java:370)
	at com.atlassian.jira.issue.fields.DefaultFieldManager.getAvailableCustomFieldsWithScope(DefaultFieldManager.java:585)
	at com.atlassian.jira.issue.fields.DefaultFieldManager.getAvailableNavigableFieldsWithScope(DefaultFieldManager.java:497)
	at com.atlassian.jira.issue.fields.DefaultFieldManager.getAvailableNavigableFieldsWithScope(DefaultFieldManager.java:449)
	at com.atlassian.jira.issue.fields.layout.column.ColumnLayoutImpl.getVisibleColumnLayoutItems(ColumnLayoutImpl.java:50)
	at com.atlassian.jira.plugin.issuenav.service.issuetable.AbstractIssueTableCreator.getDisplayedColumns(AbstractIssueTableCreator.java:315)
	at com.atlassian.jira.plugin.issuenav.service.issuetable.AbstractIssueTableCreator.create(AbstractIssueTableCreator.java:191)
	at com.atlassian.jira.plugin.issuenav.service.issuetable.DefaultIssueTableService.createIssueTableFromCreator(DefaultIssueTableService.java:188)
	at com.atlassian.jira.plugin.issuenav.service.issuetable.DefaultIssueTableService.getIssueTable(DefaultIssueTableService.java:302)
	at com.atlassian.jira.plugin.issuenav.service.issuetable.DefaultIssueTableService.getIssueTableFromFilterWithJql(DefaultIssueTableService.java:124)
	at com.atlassian.jira.plugin.issuenav.IssueNavAction.performSearch(IssueNavAction.java:1161)
	at com.atlassian.jira.plugin.issuenav.IssueNavAction.doNav(IssueNavAction.java:381)
	at com.atlassian.jira.plugin.issuenav.IssueNavAction.doDefault(IssueNavAction.java:245)
	at sun.reflect.GeneratedMethodAccessor1223.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
	at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56)
	at webwork.action.ActionSupport.invokeCommand(ActionSupport.java:438)
	at webwork.action.ActionSupport.execute(ActionSupport.java:157)
	at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:87)
	at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
	at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31)
	at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16)
	at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35)
	at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:225)
	at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:154)
	at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:152)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
	at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22)
	at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
	at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
	at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:39)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
	at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38)
	at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
	at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60)
	at com.atlassian.prettyurls.filter.PrettyUrlsCommonFilter.preventDoubleInvocation(PrettyUrlsCommonFilter.java:38)
	at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:74)
	at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56)
	at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:30)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
	at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:82)
	at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:169)
	at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
	at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:61)
	at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:749)
	at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:487)
	at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:412)
	at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:339)
	at com.atlassian.jira.plugin.issuenav.IssueNavRewriteFilter.doFilter(IssueNavRewriteFilter.java:101)
	at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92)
	at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36)
	at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103)
	at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87)
	at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:181)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:85)
	at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124)
	at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87)
	at com.atlassian.jira.mobile.servlet.filter.MobileRedirectFilter.doFilter(MobileRedirectFilter.java:59)
	at com.atlassian.jira.mobile.servlet.filter.DesktopSwitchFilter.doFilter(DesktopSwitchFilter.java:46)
	at com.atlassian.jira.mobile.servlet.filter.MobileAuthenticationFilter.doFilter(MobileAuthenticationFilter.java:92)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:234)
	at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100)
	at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
	at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
	at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
	at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
	at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
	at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:74)
	at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
	at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(JiraGzipFilter.java:55)
	at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
	at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
	at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
	at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:78)
	at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:41)
	at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:57)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603)
	at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
	at com.atlassian.jira.issue.fields.config.persistence.FieldConfigPersisterImpl.getFieldConfig(FieldConfigPersisterImpl.java:171)
	at com.atlassian.jira.issue.fields.config.persistence.FieldConfigSchemePersisterImpl.transformToDomainObject(FieldConfigSchemePersisterImpl.java:269)
	at com.atlassian.jira.issue.fields.config.persistence.FieldConfigSchemePersisterImpl.getFieldConfigScheme(FieldConfigSchemePersisterImpl.java:184)
	at com.atlassian.jira.issue.fields.config.persistence.CachedFieldConfigSchemePersister.access$501(CachedFieldConfigSchemePersister.java:39)
	at com.atlassian.jira.issue.fields.config.persistence.CachedFieldConfigSchemePersister$FiledConfigByIdCacheLoader.load(CachedFieldConfigSchemePersister.java:162)
	at com.atlassian.jira.issue.fields.config.persistence.CachedFieldConfigSchemePersister$FiledConfigByIdCacheLoader.load(CachedFieldConfigSchemePersister.java:157)
	at com.atlassian.cache.memory.MemoryCacheManager$3$1.apply(MemoryCacheManager.java:104)
	at com.google.common.collect.ComputingConcurrentHashMap$ComputingValueReference.compute(ComputingConcurrentHashMap.java:355)
	at com.google.common.collect.ComputingConcurrentHashMap$ComputingSegment.compute(ComputingConcurrentHashMap.java:184)
	at com.google.common.collect.ComputingConcurrentHashMap$ComputingSegment.getOrCompute(ComputingConcurrentHashMap.java:153)
	at com.google.common.collect.ComputingConcurrentHashMap.getOrCompute(ComputingConcurrentHashMap.java:69)
	at com.google.common.collect.ComputingConcurrentHashMap$ComputingMapAdapter.get(ComputingConcurrentHashMap.java:393)
	at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:63)
	... 269 more
The same thing for the filter "Reporter By me"
The Techinical Detail message is:
	at com.atlassian.jira.plugin.issuenav.IssueNavAction.doNav(IssueNavAction.java:370)
	... 269 more
