Bug when i move a task on a projet to another project
EspaceProprio August 30, 2016
Hi
I have a bug with the plugin JIRA Ultimate Role Tracking and Estimation.
On a task, when i try to move a task on a project to another project, i got error 500. If i disabled the plugin, its work.
Here the info of the error :
http-bio-8443-exec-3126 ERROR      [o.a.c.c.C.[.[localhost].[/].[action]] Servlet.service() for servlet [action] in context with path [] threw exception [java.lang.NullPointerException] with root cause
        at java.text.SimpleDateFormat.parse(SimpleDateFormat.java:1439)
        at java.text.DateFormat.parse(DateFormat.java:364)
        at com.adweb.estimations.Utilities.stringToDate(Utilities.java:146)
        at com.adweb.estimations.Utilities.validateLogWork(Utilities.java:1537)
        at com.adweb.estimations.customFields.logWorkByRole.LogWorkByRoleCFType.validateFromParams(LogWorkByRoleCFType.java:217)
        at com.atlassian.jira.issue.fields.CustomFieldImpl.needsMove(CustomFieldImpl.java:1134)
        at com.atlassian.jira.bulkedit.operation.BulkMoveOperationImpl.fieldNeedsMove(BulkMoveOperationImpl.java:981)
        at com.atlassian.jira.bulkedit.operation.BulkMoveOperationImpl.fieldNeedsMove(BulkMoveOperationImpl.java:950)
        at com.atlassian.jira.bulkedit.operation.BulkMoveOperationImpl.setMoveFieldLayoutItems(BulkMoveOperationImpl.java:911)
        at com.atlassian.jira.bulkedit.operation.BulkMoveOperationImpl.finishChooseContext(BulkMoveOperationImpl.java:476)
        at com.atlassian.jira.bulkedit.operation.BulkMoveOperationImpl.finishChooseContext(BulkMoveOperationImpl.java:468)
        at com.atlassian.jira.web.action.issue.bulkedit.BulkMigrate.doChooseContext(BulkMigrate.java:158)
        ... 3 filtered
        at java.lang.reflect.Method.invoke(Method.java:498)
        at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
        at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56)
        ... 2 filtered
        at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63)
        ... 7 filtered
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
        ... 50 filtered
        at com.atlassian.greenhopper.jira.filters.ClassicBoardRouter.doFilter(ClassicBoardRouter.java:59)
        ... 62 filtered
        at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:70)
        ... 89 filtered
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
        at java.lang.Thread.run(Thread.java:745)
Abhinav Ojha
August 31, 2016
Hi Tony,
Thanks for pointing out the bug. We have fixed it with the new version release of the plugin :
JIRA 7+ : Version 1.8
JIRA 6+ : Version 1.4
For support, you can freely ask questions here, as we check these questions quite regularly and always try to respond with a solution as soon as we can.
For further support, you can find the direct contact details here : https://marketplace.atlassian.com/vendors/1211262
Hope this helps. Please let us know, if you have any further queries.
Abhinav.
EspaceProprio August 31, 2016
Hi  Abhinav Ojha
I have update the plugin, and now its work!
Tnx for the update!
Hi Joe. On the plugin, its say to ask the question here...
Joe Pitt
Interesting. Sounds like it doesn't have formal support.
Joe Pitt
I suggest contacting whoever wrote the plugin.
