×I have installed script runner from:
https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner
and I am using the Built In scripts to bulk import custom field options for a Select List as explained in:
The problem I am facing is that after the script runs and imports the options, in the Single Select the options arent in the order I provided during the import.
For example, this is the list I provided during import:
Alpha - A
Beta - B
Development - D
Early Install - E
Limited Production - L
Production - P
But this is the order of options I see after the import:
Alpha - A
Beta - B
Production - P
Early Install - E
Development - D
When I have more than 30 options, the order of the options is even more random.
How do I make sure that the options in the Single Select are in the order I provide during import using Script Runner?
I agree with Fahd that this is a bug, but not necessarily that you should create a ticket before establishing it is a bug. In this case though I think it is, although imho com.atlassian.jira.issue.customfields.manager.OptionsManager#createOption should respect the order of creating and not insert them randomly.
I think your best bet is just to import them then sort them alphabetically, which imho is always clearer for users than a custom ordering.
Unfortunately there are situations when sorting alphabetically doesn't fit, like weekdays, months etc. :(
Hi Ashok,
I would highly suggest that you raise a ticket in the plugin's issue tracker to address this issue to its developer - https://jamieechlin.atlassian.net
I believed this is something that need to be fixed within the plugin's codes itself.
Fahd
Hi Ashok,
Can you provide me the code for
thanks in advance.
Sumit
