Hello together,
I have a question. I have projects with storys and the storys have subtasks.
In the case the the story set to the status Closed, I want to close all the subtasks of this story, too.
Is this possible?
Regards
Nadine
You can set this as a project rule but this would mean that it would happen for all stories in that project.
Go to project settings -> automation and then you can create automation so that when your story is set to closed, then your sub-tasks (in issue) will close.
Hope this helps.
Jacob
Hi Jacob,
thank you for your answer, but I can't find the settings in the project. I click on the project and then where can I find these settings?
Regards
Nadine
Do you have ScriptRunner (not advertising for the company)?
This can be done using a script in a post function that will close all subtasks when a parent is closed.
Not sure if there are other plugins to help you with your request.
Let me know if you have any other questions
Best,
Fadoua
