Bulk edit fix versions across multiple projects
Jonathan Kernan
Hi folks,
I have multiple projects with the same fix versions. How can I bulk edit the fixVersion of each project.
Is it possible to create some sort of script? The manual way would be to have a filter for each project and label it with "BULK" or something like that and just update it depending on the fix version.
Vera Henrichs
February 29, 2016
And how about this?
https://jira.atlassian.com/browse/JRA-59992
Please vote for it, thanks!
