Bulk resolve issues with SIL Power Scripts
Daniel Völker February 25, 2019
I'm trying to resolve erroneous issues from broken Workflows via SIL Scripts.
I tried the following:
string issueKey = "ISSUE-193";
%issueKey%.resolutionID = 1;
%issueKey%.resolutionDate = currentDate();
 Unfortunately, it doesn't update the resolutionDate. Any ideas on the correct format for the resolutionDate and how to set it in SIL?
Alexey Matveev
February 25, 2019
The resolutionDate field is a read-only field. You can find it in documentation:
https://confluence.cprime.io/display/SIL/Variable+resolution
You can not change it.
Alexey Matveev
February 25, 2019
And you do not need to change it. It will be set to the currentDate, I suppose.
Daniel Völker February 27, 2019
Unfortunately, the resolutionDate is not set when using %issueKey%.resolutionId = 1; for example.
I tried to raiseEvent the 'Issue Resolved' event, still no luck. This is rather unfortunate, the event should really be triggered.
Alexey Matveev
February 27, 2019
Are you on Cloud or Server? Could you provide your complete code?
Alexey Matveev
February 27, 2019
Or I will take your code like this:
Yes, I tried exactly the code you posted and also something more elaborate like:
string issueKey = "ISSUE-149";
%issueKey%.resolution = "Gelöst.";
raiseEvent("Generic Event", issueKey, currentUser());
raiseEvent("Issue Updated", issueKey, currentUser());
raiseEvent("Issue Resolved", issueKey, currentUser());
raiseEvent("Issue Closed", issueKey, currentUser());
I have no luck with the resolutionDate.
Alexey Matveev
February 27, 2019
Do you use Jira Cloud or Jira Server?
Hi Alexey,
I'm on Jira Server.
Alexey Matveev
February 27, 2019
I tried your code and it worked for me.
You can use a code like this:
%issueKey%.resolution = "Gelöst";
And it should work. If it does not work, then try to change Gelost to the English analog as you can see in the issues->resolutions.
You can also use:
But I believe that your id is wrong. The id of a resolution is a 5 digit number. You can find out the id of a resolution, if you go to issues -> resolutions and then hover your mouse over the edit button. You will see a url with the id of the resolution.
Hello Alexey,
just to clarify: when you set the resolution with SIL, ist the resolutiondate of the issue also updated? That's my problem. The resolutiondate stays null.
Alexey Matveev
March 1, 2019
Hello Daniel,
I asked the developers of the plugin. It is currently not possible to set the resolution date with Power Scripts
Like Iuri Pereira likes this
Daniel Völker March 1, 2019
Thank you for your effort, Alexey!
Iuri Pereira
If your problem is to fix resolution date to an specific date for N issues, there's  way to do it with JSU Plugin
1. Create a transition (e.g. Fix Resolution) in your workflow to the same final status
2. Add a post function in this transition and choose "Update Any Field (JSU)"
3. Choose "Resolved" and set to the date you wish to change
4. Publish the workflow
Make sure this transition is not changing anything but the Resolved field and make sure this transition is going to the same final status. The problem with this is that every time you need to change the final date you need to change in the transition and re-publish the workflow.
Hope this can help!
