Is it possible to create a Burndown Chart that involves the whole project? We have Burndowns currently for individual sprints, but we would like to have a visual for the whole project.
I've explored the two plugs in listed below, to no avail:
AIO Reports and Timesheets for Jira
Great-Gadget
Any help would be greatly appreciated!
Thank you,
I would start by investigating the options provided by VisualScript as part of their no-code solution https://www.visualscript.com/burndown-chart/burndown-charts-for-jira.htm but this may not be enough for your scenario listed above so you can then use their SDK to build your own custom reports.
You can also reach out to Evan Golden egolden(at)visualscript.com to discuss your scenario further for other suggestions.
Hope this helps
Phill
I use Jira rest api to pull the project ticket data and then draw burn up graphs
I can't think of a way to do this, because burndown is a function of a sprint.
