CROWD 2.7.1 - Compatibilities with JIRA v. 5.1.8 and JIRA v. 5.2.11
Cedric DEVAUX May 14, 2014
I don't find anywhere in the release note of Crowd 2.7.1 if it compatible with JIRA 5.18 and JIRA 5.2.11
Can you help me?
Thanks.
Cedric
Nic Brough -Adaptavist-
May 14, 2014
It's well buried, but https://confluence.atlassian.com/display/CROWD/Integrating+Crowd+with+Atlassian+JIRAcovers it.
(To save you a bit of time, it's fine - as long as you're on Jira 4.3 or above)
Bob Scott
Thanks Nic. It helped
Cedric DEVAUX May 15, 2014
OK Thank you for your help
Caspar Krieger
May 15, 2014
As an unrelated note, we (the Crowd team) very strongly recommend upgrading to Crowd 2.7.2 as soon as possible, as it contains a number of very important fixes.
