Hi
My requirement is to have 2 calculated members on the Project domain; to filter out the jobs that two separate teams will have worked on.
Here's the proposition....
We have two separate development teams that work on 3 separate projects, for simplicity let's call the teams "Team A" and "Team B" and the projects "Project X", "Project Y" and "Project Z".
"Team A" will work on
"Team B" has a much more complex way of working and will work on all the other components in each project bar the ones worked on by Team A i.e.
I want to be able to have two calculated members on the project domain that filter out all the issues according to the rules above.
In trying to implement this I first built this calculated member which I called "Team A Project Jobs"....
Aggregate({
[Project].[X].[Component 1],
[Project].[X].[Component 2],
[Project].[Y].[Component 1],
[Project].[Y].[Component 3],
[Project].[Z].[Component 1],
[Project].[Z].[Component 2],
[Project].[Z].[Component 3]
This appears to work - but in defining "Team B Project Jobs" I don't want to name each component. I would have thought that I could use an approach below - but that appears to still bring through the components that Team A work on
Aggregate(
Except(
[Project].[Component].Members,
[Project].[Team A Project Jobs]
Please can you help - I'm 4 hours into trying to crack this one and I'm losing my mind?
Hi Graem,
I would suggest extracting the numeric part from the component name and then do some numeric operations with extracted number.
You could try this formula for calculated member 'Team B Project Jobs':
Aggregate( Filter( [Project].[Component].Members, ([Project].CurrentHierarchyMember.Parent.Name = 'Project X' AND Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) >= 5 AND Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) <= 20 ) OR ([Project].CurrentHierarchyMember.Parent.Name = 'Project Y' AND Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) >= 15 AND Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) <= 30 ) OR ([Project].CurrentHierarchyMember.Parent.Name = 'Project Z' AND Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) >= 5 AND Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) <= 12 ) ) )
Daina / support@eazybi.com
Thanks for taking the time to answer this Daina. Unfortunatley, in the example, for clarity I gave component names such as Component 1 and Component 2 etc. However, in reality the components are named such as ".NET" and "MySQL" and "Oracle" etc etc
Without wishing to sound desperate (although I am), please can anyone advise?
