Calculated Members - How to filter based on project component in EazyBI?
graemejohnson
Hi
My requirement is to have 2 calculated members on the Project domain; to filter out the jobs that two separate teams will have worked on.
Here's the proposition....
We have two separate development teams that work on 3 separate projects, for simplicity let's call the teams "Team A" and "Team B" and the projects "Project X", "Project Y" and "Project Z".
"Team A" will work on
  • jobs in "Project X" where the Component is "Component 1" or "Component 2"
  • jobs in "Project Y" where the Component is "Component 1" or "Component 3"
  • jobs in "Project Z" where the Component is "Component 1" or "Component 2 " or "Component 3" or "Component 4"
"Team B" has a much more complex way of working and will work on all the other components in each project bar the ones worked on by Team A i.e.
  • jobs in "Project X" where the Component is "Component 5"  all the way to "Component 20"
  • jobs in "Project Y" where the Component is "Component 15" all the way to "Component 30"
  • jobs in "Project Z" where the Component is "Component 5" all the way to "Component 12"
I want to be able to have two calculated members on the project domain that filter out all the issues according to the rules above.
In trying to implement this I first built this calculated member which I called "Team A Project Jobs"....
Aggregate({
[Project].[X].[Component 1],
[Project].[X].[Component 2],
[Project].[Y].[Component 1],
[Project].[Y].[Component 3],
[Project].[Z].[Component 1],
[Project].[Z].[Component 2],
[Project].[Z].[Component 3]
This appears to work - but in defining "Team B Project Jobs" I don't want to name each component.   I would have thought that I could use an approach below - but that appears to still bring through the components that Team A work on
Aggregate(
Except(
[Project].[Component].Members,
[Project].[Team A Project Jobs]
Please can you help - I'm 4 hours into trying to crack this one and I'm losing my mind?
Daina Tupule eazyBI
January 26, 2017
Hi Graem,
I would suggest extracting the numeric part from the component name and then do some numeric operations with extracted number.
You could try this formula for calculated member 'Team B Project Jobs':
Aggregate(
   Filter(
     ([Project].CurrentHierarchyMember.Parent.Name = 'Project X'
         AND
         Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) >= 5
         AND
         Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) <= 20
     OR
     ([Project].CurrentHierarchyMember.Parent.Name = 'Project Y'
         AND
         Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) >= 15
         AND
         Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) <= 30
     OR
     ([Project].CurrentHierarchyMember.Parent.Name = 'Project Z'
         AND
         AND
         Val(ExtractString([Project].CurrentHierarchyMember.Name, '.* (\d+)', 1)) <= 12
Daina / support@eazybi.com
graemejohnson
Thanks for taking the time to answer this Daina.  Unfortunatley, in the example, for clarity I gave component names such as Component 1 and Component 2 etc.  However, in reality the components are named such as ".NET" and "MySQL" and "Oracle" etc etc sad
graemejohnson
Without wishing to sound desperate (although I am), please can anyone advise?
