Can I Create an Issue as part of a workflow of another issue?
Naama Lev
December 14, 2014
Hello Experts,
Can you please let me know if it is possible
That a status in one issue type workflow will trigger creation of another issue type?
Naama
Steve Thornhill
December 14, 2014
Yes, you can add a post function to do that.
Take a look at Script Runner if you do not already have that installed as a plugin. There are examples in there that will allow you to create sub-tasks, etc
Naama Lev
January 20, 2015
Hi Steve, Thanks for that! Do you have example how to create a new issue that takes it's data from the another issue? Thanks Naama
Steve Thornhill
January 20, 2015
If you are going down the script runner route, when you add the post function to create a sub task you will have a variety of options to add detail from the parent. The Summary is one of the main option, but under additional actions you can set custom fields from those of the parent. So basically, edit your workflow, in the transition where you need a sub task, add a post function and select script postfunction, then select the create subtask option.
Bob Swift
December 15, 2014
Create Issue post function from Create on Transition for JIRA. Use How to condition the creation of issues to condition the create on the status of the issue being transitioned.
