Can I Log work outside of issue?
Matías Castro Rojas
June 21, 2016
Hi, this is for the support team of work calendar.
Can I log work time unrelated to an issue? If not, can it be done or is it in the roadmap?
This would be very useful since not everything is issued (like meetings or research time).
Thanks a lot!
Volodymyr Krupach
June 21, 2016
Hi Matias,
In JIRA all worklogs are tied to issues. Personally for such "not direct" activities I have separate project with tasks like Meetings, Stand-ups, Research and so on. Other way is to introduce appropriate tasks in your current project or even better is to add corresponding issue types. You should do it in a way that suits you most.
Matías Castro Rojas
June 21, 2016
Thanks. I'm doing the same thing, but I wanted to know if there was another way. Cheers.
