Hello mate,
Hope you are having a nice day.
From what it seems, you are using Jira Cloud free version, right?
Are you using next-gen or classic projects?
In case you are using classic projects, you can just edit the workflow and add more status to it. Atlassian has a complete step by step tutorial that you can check in the links below:
In case you are using next-gen projects, I recommend the article below:
Please let me know if it helps. :)
Carlos
