Can I copy/clone settings from a current project into a new project in Jira Software?
Daniel_Oborne
I've been asked to create a new project, using the settings/issue templates/etc. from an existing project. I'm seeing a lot of how-tos on how to do this in different versions of Jira; but is there any way to do it in Jira Software?
Ste Wright
Hi @Daniel_Oborne
You can create a new project, sharing a range of settings with an existing one:
  1. In Jira, go to Projects > Create Project
  2. Check the box "Share settings with an existing project"
  3. Continue on to create the project
^ This will re-use the existing schemes on a new project. This doesn't clone/create new ones - it just means the new and existing projects will share common workflows, issue types, screens, fields, permissions, notifications, etc.
See more information on Shared Configuration on this page.
Note: This is for Classic projects only. It is currently not possible to share schemes across Next-Gen projects.
Ste
Daniel_Oborne
Thank you. I've been told that the share settings option is available, but while trying to do this for a Next-Gen project, I haven't been seeing it.
Like # people like this
Ste Wright
Hi @Daniel_Oborne
Yeah - it's not available in Next-Gen at this stage, as each project and its configuration is designed to be entirely independent from all others.
There is a feature request to allow this though - check-out JSWCLOUD-17430
Ste
Drew McManus
I have to say I get increasingly frustrated with these "nope, can't do that on a next-gen project" scenarios for something that should be an obvious default feature. When will Atlassian begin paying me for the time it takes to recreate settings that could have been saved with the option that was available in the OLDER version?
David Mansueto August 18, 2021
I was stumped for a while here, perhaps project creation has changed since @Ste Wright 's answer.
There is now an extra step:
1b. Follow through the prompts, selecting the same Template and Management Type as the Project you wish to Share Settings with.
Like Marcelo Castello likes this
Ste Wright
To add to David's instructions, this is the new process for Company-managed (formerly Classic) Projects:
  1. Select Projects > Create Project
  2. Select a template - for example, Kanban
  3. Select the button Use template
  4. Select a company-managed project
  5. On the next screen, Add project details, the box Share settings with an existing project is possible to check
Ste
Léo Boulanger November 5, 2021
When using this way, my Project gets a undefined error when creatign and the new project then has no settings at all, no boards and so on.
sweixelbaumer December 12, 2022
 @Ste Wright
Again it is still not possible to copy any settings from team-managed to company-managed projects.
Stephen_R
March 28, 2023
Also please note, copying settings from company-managed projects is only available to paid users (or during free trial periods on Standard Plans and above).Screen Shot 2023-03-29 at 7.11.16 am.png
Like programeriss likes this
Shyam Penubolu
August 17, 2024
Hi all, I am experimenting with the copying settings from an existing project. I created a test company-managed project and checked the 'Share settings with an existing project' checkbox during the creation process.
The source project has a board but the newly created project does not. The sidebar shows a 'Board' dropdown but when  clicked, displays text saying that the new project does not have a Board. Also, the source project has a Backlog which does not show up in the new project. I hope I am not missing something basic. Thanks in advance for your help.
W.L
Hi @Daniel_Oborne
Jira software supports, team-managed or company-managed projects. As you are looking to reuse settings, company-managed projects are the way to go, because as others pointed out, reusing settings is not supported in team-managed projects yet.
Without addon, your best option would be to use the 'Create with shared settings' button during project creation. This helps to reuse settings, but comes with some limitations in terms of what can be copied and is also not as user friendly as specifying your own custom templates.
If that is what you are looking for, you'll find third party solutions, that allow you to create custom project templates on Jira cloud on the marketplace. Take a look:
https://marketplace.atlassian.com/search?hosting=cloud&query=project%20templates%20%2B%20jira
Jessica Venditti July 19, 2021
The hardest part of the cloning from one project to the next is the workflows. I cannot find out how to do this and have gone through a few to -do and have not found the way. We have a team-managed project and we have created a great workflow but to do manually will take some time so looking for a short cut for sure.
Ste Wright
Hi @Jessica Venditti
Team-managed Projects used to be called Next-Gen.
It's not possible to share Workflows between different Team-managed projects at this stage, only Company-managed.
Ste
Jessica Venditti August 2, 2021
Thanks - I was able to re-create to get this completed.
Nita Sexton
Any easy work arounds for this issue at this time other than manually doing a do-over?
Like James Finlinson likes this
