I need to create JIRA issue from transition screen, if user checks a checkbox.
Use case:
Developer:
- Fixes a bug;
- Clicks on "Ready for QA" transition button;
- JIRA shows "Ready for QA" transition screen with "Need Documentation" checkbox;
- If the developer checks the checkbox, JIRA creates issue of type "Documentation".
I believe this can be done using the Create on Transition for JIRA from Bob Swift; but I'm afraid this isn't possible by default.
