Can I create a Jira card and have it populate to a trello board
Lori Carruthers
March 2, 2021
Is it possible to create a new issue/card from Jira and have it populate on a Trello board? For example I created a task in Jira and then automatically this task is adding to Project board in Trello?
Jillian Amyot _Unito_
Hi @Lori Carruthers ,
Welcome to the community! If you'd like to integrate Jira + Trello, you can use the company I work for, Unito. We create 2-way syncs, so information can freely flow between both tools, no-code required! Here's a page with more information, and here's a webinar showing you how to set it up. Hope this helps :)
Michaela Staffova
Hi @Lori Carruthers :)
Since there's no native solution to this, I would suggest checking out Integromat. It's an automation platform that lets you connect pretty much any apps. Just to give you an idea of what the automations can look like - there is a pre-made template that creates issues in Jira for new Trello cards. You just flip the script and are all set :)
Trudy Claspill
Hello @Lori Carruthers
Welcome to the community.
That functionality is not available out of the box with JIRA Cloud. You will have to utilize an add-on/app to support that integration.
If you do an internet search for "jira cloud trello integration" some of the apps available in the Marketplace will show up in the results.
