Can I create a issue collector that works from a button on a webpage rather than a banner?
Samuel Pascoe
February 3, 2022
I am creating a feedback form in Jira Software using the issue collector.
*Please note I am a beginner when it comes to using Jira so I am still learning*
I understand the default trigger for the form is a 'pop-up' banner that will appear on the webpage. I see that there is a custom option that requires some manual input which I am also un-experienced in.
Within this input, is there an option for the trigger to be linked with a dedicated button on a website rather than having a banner?
What is required to do this? If it is possible if you can provide the code (? note sure if it is code?) that I will need, or leave a really low level set of instructions on how to do it?
Many thanks, I appreciate any help left :)
Angélica Luz
February 4, 2022
Hello @Samuel Pascoe,
On the Issue Collector, it’s possible to customize some information using JavaScript, but there is not much to do via the UI.
There are some details about customizing the issue collector on the documentation below:
Also, there are some feature requests suggesting improvements:
If the documentation doesn’t help, I would suggest you post your question on our Developer Community since your question is not related to usability, but the customization of the feature.
Angélica
