×We need to do demo on producion and then tickes will be created. We need to restore back origional start index starting from 1 again.
You can't without messing with the database. Just delete and recreate the project.
what about deleing projec issues from daabase and do reseeding to the icke number
Does deleing project deletes all customizaion we made regarding fields, notification, permission scheme; what are the hings I might rebuild when deleting a project?
Remember that a project is a header - it lists the field, notification, permission, screen, workflow SCHEMES that make up the project. If you delete a project, you lose the list of schemes you had in use, but you do NOT lose the schemes themselves.
Deleting and recreating a project is mostly going to be the best way - I simply take a copy of the schemes it's using before deletion. The more painful bit is components and versions if you want to preserve them.
FWIW, Deleting from the database is a monumental pain in the neck. You have to understand all the relationships and tables affected - jiraissues is a start, but you then need to deal with changegroup and changeitem, customfieldvalue, the workflow tables, and so-on. Then there's the need for downtime, proven backups and reindexing etc. It's FAR more easy to use the UI or scripts.
Yes, it deletes all customisations. You could try the script runner plugin (https://studio.plugins.atlassian.com/wiki/display/GRV/Script+Runner) which has a built-in script to copy a project with customisations (but without issues).
Great answer, Yes I think only components I need to re create them. and re-associate the fields/screens .. to the project.
I wish this is all about I need to do.
JIRA Command Line Interface has a cloneProject action that will get you most of the way there. In your case, clone project to a temporary, delete old one, then clone temporary to replace the original. You will need to fix up a few things that clone doesn't currently cover. In your case, you will need to use:
--copyVersions --copyComponents --copyRoleActors
