×My company wants to move off jira. Can I export a jira project into csv? if so, how/
Run a filter for "project = XYZ", then use the "export to CSV" from the tools menu.
Hi!
you can export as json :)
https://github.com/sgreben/jira-project-export
1. Also, I suggest to do a xml backup for export.
2. Also, you can read that thread
Gonchik Tsymzhitov
Hi @Samantha Diegutis what do you want to export, the issues in the project or the project attributes like workflows, schemes etc. too?
