Can I export a Jira project? if so, how?
Samantha Diegutis
March 2, 2019
My company wants to move off jira. Can I export a jira project into csv? if so, how/
Nic Brough -Adaptavist-
March 2, 2019
Run a filter for "project = XYZ", then use the "export to CSV" from the tools menu.
Gonchik Tsymzhitov
Hi!
you can export as json :)
https://github.com/sgreben/jira-project-export
1. Also, I suggest to do a xml backup for export.
2. Also, you can read that thread
https://community.atlassian.com/t5/Jira-questions/How-to-export-or-backup-a-single-project/qaq-p/222726
Gonchik Tsymzhitov
Capi [resolution]
Hi @Samantha Diegutis what do you want to export, the issues in the project or the project attributes like workflows, schemes etc. too?
