Can I move issues from one project to another in bulk?
Molly Favret April 11, 2012
I have a bunch of UAT projects set up, and am going to be moving those projects to production (which involves creating a new project key, and starting with key-1). There are a number of issues in the UAT project that I need to move to the production project. Is there a way to do this in bulk, without having to enter each individually and select move?
Ramiro P
April 11, 2012
Yes there is. You can go to the 'Issue Navigator' and make the search to show all the issues that you want to move. Then in the right corner you can click 'Tools' and then choose 'Move In Bulk' (or something like that). Then follow the steps to move the issues.
Remember that your user needs to have permission for this.
Thanks! I didn't see that option because I didnt have the permission enabled, but have made the change. This is exactly what I was looking for.
Like Chidanand Ayyavoo likes this
