Can I move my JIRA installation and home directories?
Arthur Frohlich
October 9, 2013
I've installed JIRA in a directory, .../confluence/jira-6.0.5/. This directory holds jira/ and jira-home/. Is there a way to move the jira/ and jira-home/ directories into the confluence/ directory?
Nic Brough -Adaptavist-
October 9, 2013
I wouldn't do this. You should have separate directories for confluence and jira, otherwise you could end up with clashing names. By all means do something like .../atlassian/confluence and .../atlassian/jira, but do not just do .../confluence (and point both Jira and Confluence to use that as their home)
Once you've worked out a sensible tree structure, then Rambanam's link will tell you how to relocate everything safely
RambanamP
October 9, 2013
October 9, 2013
Yes, and that's easier, because it doesn't really care where they are. As long as you preserve the structure and file ownership/rights, you should be able to simply move the whole lot.
(Ooops, I forgot, "and don't put the application in the home directory")
Arthur Frohlich
October 9, 2013
Thanks for the replies. rambanam's link only says how to move the home directory files. Can I move the install directory?
