I created an issue in the wrong project. Can I simply tranfer it to the correct project?
Yes. You need to have "move" permissions in the source project and "create" in the target. Then you should find "move" on the options list.
Eh? That's what we answered for ("issues" and "project" imply Jira)
yes, you can "Move" it to a different project from the "More Actions" menu.
This issue was in Jira
