Can I view more than 7 sprints in a speed report?
Nico F_A_
August 11, 2020
Is it posible to generate reports with the bar graphs showing more than the last 7 sprints that were completed?
Bill Sheboy
August 11, 2020
Hi @Nico F_A_  -- Welcome to the Atlassian Community!
I am unclear what the speed report is.  Do you mean the Velocity Chart:
https://support.atlassian.com/jira-software-cloud/docs/view-and-understand-the-velocity-chart/
If so, the answer is "no" as that report shows up to the last seven sprints.
Of note, looking further back in time/iteration count may not be helpful.  Often things change such that looking at old velocity may not be helpful.  Such changes could include: team capacity, mix of work items, team improvements in workflow, etc.
In addition, I believe there are suggestions to expand the range of sprints reported upon.
Best regards,
Nico F_A_
August 11, 2020
Thank you! What you say about past sprints becoming a little irrelevant in terms of Velocity Charts makes sense now that you explain it to me that way.
And yes, I was referring to the Velocity Chart. Sorry for using the wrong term.
Like Bill Sheboy likes this
FREE
