Can I write a query across any project for issues where I am a watcher?
BoredWithTech June 23, 2020
I am a watcher on issues across many projects. I would like to create a query for issues where I am a watcher across any project. Is that possible and how do I do that? Thank you.
Sachin
June 23, 2020
Try this JQL: watcher = currentUser()
Thanks, that worked. I have other queries in which I used my user name instead of currentuser(). I tried that with the watcher field, but i got a message saying the value was not valid.
Sachin
June 23, 2020
What is the JQL you are using ? did you use "watcher = username"
Yes, that was it. It works with other fields such as reporter.
