We recently upgraded our JIRA instance to version 6.x and we would like to use JIRA Issue Collector to allow users to anonymously create issues. But when I go to install the plugin from the plugin manager it cannot be found. Is this plugin 5.x only? If so, is there a time frame when it should be compatible with 6.x? Thanks.
It is a bundled plugin in JIRA now. Check the System Plugins section and you will find it there.
Apologies. I should've known that. Thanks for the quick reply!
