Can Jira Work Management Select Approvers automatically based on a field value in Jira Forms?
Claudia Vidarte
December 8, 2023
BHUSHAN PATIL
December 8, 2023
Hi @Claudia Vidarte
Yes, in Jira Work Management, you can select approvers automatically based on a field value in Jira Forms. To achieve this, you can link a form field with a Jira custom field and use it to capture the value from forms. Then, you can configure the approval step in the workflow and modify the approver based on the values selected in the Jira form field.
For more details refer following document:
Also, if you feel my input help you please accept the answer.
Bhushan
