Is it possible to make a specific field (regardless if it is a custom or not) to be mandatory for project AAA and not be mandatory for project BBB when a specific issue type is created?
Both projects are company managed
Hi @Sherwin Soriano - Yes, like @Jack Brickey mentioned, you can make use of the Field Configurations option. Make sure you create a new one and add this to the project that needs the mandatory field before you make adjustments to the Default Field Configuration, because that might make the field mandatory in all projects.
