I would like to get the jira cards as static images instead of cards to be printed for offline work.If the cards are printed as images it could be used to reference in visio.
On the board if you have ellipses in the top RH corner there is a Print cards option. Is that what you are using and it is not meeting your needs?
Hi there,
By default theres no good option for this.
You can use some plugins:
Only used to print the issuesas agile cards.
It has many utilities to printing issues in many ways
