Components can not be added to my project. The fields are there and I can enter values, but once I hit the "Add"-button, the screen empties and the component is not added.
One of my asssumptions was that it was due to the project type, which initially was "Business", so I changed it to "Software". Still not possible to add Components.
Please help asap
Hi Tina Vincent,
image2016-7-4 10:37:52.png
If you did it and not works. You have not permission to do it or there is a bug at the feature, and you should report to Atlassian Support.
Lameck.
I found my issue :
Thanks Lameck. This is exactly what I did. I've done it before at other customers, so something is weird here. I'll report it.
