I have problems finishing my jira installation on a Debian 6 virtual private server.
The outpout was:
Verweiser-URL: Unknown
java.lang.IllegalStateException: You cannot perform an import with an invalid validation result. Errors: {} Error Messages: [ActiveObjects-Plugin kann nicht gefunden werden. Das Plugin muss aktiviert werden, damit die Wiederherstellung funktioniert.
Output with full Stackrace and jira-log appended (jira-output.txt) (atlassian-jira.log) .
Some System Info:
# uname -a
Linux vps-848-195 2.6.32-084.14-openvz-intel #1 SMP Mon Dec 30 20:45:16 CET 2013 i686 GNU/Linux
# lsb_release -a
No LSB modules are available.
Distributor ID:Debian
Description:Debian GNU/Linux 6.0.9 (squeeze)
Release:6.0.9
Codename:squeeze
# java -version
java version "1.6.0_26"
Java(TM) SE Runtime Environment (build 1.6.0_26-b03)
Java HotSpot(TM) Client VM (build 20.1-b02, mixed mode, sharing)
I used the installer: atlassian-jira-6.2.2-x32.bin
I have the same Problem on my Ubuntu 12_04 64 bit virtual server
uname -a
Linux xthinker 3.2.0-29-generic #46-Ubuntu SMP Fri Jul 27 17:03:23 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
java -version
java version "1.7.0_60"
Java(TM) SE Runtime Environment (build 1.7.0_60-b19)
Java HotSpot(TM) 64-Bit Server VM (build 24.60-b09, mixed mode)
lsb_release -a
Distributor ID: Ubuntu
Description: Ubuntu 12.04.1 LTS
Release: 12.04
Codename: precise
Did any body solve this problem?
