Can not resolve issues when run jira under ssl
Dena E-Commerce
August 29, 2015
Hi, I install Jira in debian server, by nginx I force jira to start by ssl certification and https domain. But when I want to resolve one issue this error appear:
"The JIRA server could not be contacted. This may be a temporary glitch or the server may be down. Close this dialog and press refresh in your browser."
In another side when run jira by 127.0.0.1:8080 it allow me to resolve issue.
you can see my nginx configuration in bellow.
Please help me to know what is problem.
Thanks in advance
server {
 listen 80;
 server_tokens off;
 server_name  my domain name;
 return 301 https://$server_name$request_uri; # enforce https
server {
 listen 443 ssl;
 server_tokens off;
 ssl on;
 ssl_certificate /etc/ssl/certs/jira.crt;
 ssl_certificate_key /etc/ssl/certs/jira.key;
 location / {
 proxy_set_header X-Forwarded-Host $host;
 proxy_set_header X-Forwarded-Server $host;
 proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
 proxy_set_header Host $host;
 proxy_set_header X-Real-IP $remote_addr;
 proxy_set_header X-Forwarded-Proto https;
 proxy_pass http://127.0.0.1:8080/;
Jonas Andersson
August 30, 2015
I am not a big user of nginx, but make sure that the application base url is set to the https://<servername>
