Hi everyone!
I can´t associate issue types to my projects.
In the configuration screen, I get the following message when I want to apply a scheme: There are no projects available to associate with the issue type.
What am I doing wrong?
Thanks.
Greetings. Juan Manuel.
It means that you are on Jira Cloud and all your projects are next-gen projects. You can not associate issue type scheme to next-gen projects. You should create a classic project if you need to do it.
In Next-gen projects, you should go to project settings -> Issue Types and add a new issue type there.
@Soluciones Online S_A to associate an issue type to project, https://confluence.atlassian.com/adminjiraserver073/associating-issue-types-with-projects-861253240.html
