Can't display project after create
Eric LAUGIER
January 16, 2020
I just create a project in Jira, I can access to the administration section of this but I can't see it in my projects list.
I can create a issue but i can't access to it
No security policy is active on issues
2020-01-16 19_12_58-Projet LE LITE EXPLOITATION - Sécurité des tickets - Jira.png
I don't understand where is the problem.
Can you help me?
John Funk
Hi Eric - Either give yourself the Developer project role or add Project Role of Administrators to the Browse Projects permission (Parcourir les projets).
Eric LAUGIER
January 16, 2020
It works. Thank you!
John Funk
Great! Glad it worked.
Scott Theus
January 16, 2020
Hi Eric,
I can't tell from your screen shots whether your default permission scheme is associated with the new project or not; my guess is that it is not.
If you click the "assistance autorisation" button for the permission helper, select your user ID, the issue you created in the project, and the "browse projects" permission the helper should show you what is missing from the security settings for that project.
Hope this helps,
Scott
