I recently created a project, and then I went to create my dashboard and configure my gadgets and the dropdowns that ask to identify for which project, my dropdowns do not include the project that I created. I thought maybe it was because I didn't "categorize it" so I did that, refreshed, even logged out and back in and STILL do not see the project, why?
Yes I did have Browse permissions set up, but I have figured out the issue, I had not "enabled" my project in the greenhopper plugin. thanks for your quick response though
Hi @JanaW , can you please let me step by step how you were able to enable it. I'm trying to create a dashboard on one project but I'm not able to see the project when creating a dashboard.
I wish I could, but I am no longer an admin and don't have the permissions to enable projects in plugins. Sorry. That was a long time ago,
Do you have browse permission in the project? Are you able to browse it?
Yes I did, but I have figured out the issue, I had not "enabled" my project in the greenhopper plugin. thanks for your quick response though
